  4. UK roundabouts
UK roundabouts
28 Posts 16 Posters 554 Views 5 Watching
  • tonySundefined Offline
    tonyS
    When following a route, on approaching a roundabout the voice instructions are correct but the visual instruction (top left of screen) goes the wrong way round the roundabout. So 3rd exit displays as 1st exit and the route line goes anticlockwise around the roundabout.
    This morning I uninstalled and reinstalled app but no change.
    Samsung Galaxy A33 5G
    Samsung Galaxy Tab A8
    • tonySundefined tonyS
      @tony-v That's unfortunately a known issue with HERE. The information they provide at roundabouts is inconsistent and often incorrect since one if their updates 😞
      David Parsonsundefined Ray Wealundefined 2 Replies Last reply
        David Parsonsundefined Offline
        David Parsons
        I had the same problem
        tonySundefined 1 Reply Last reply
        • David Parsonsundefined David Parsons
          tonyS
          @David-Parsons that's it.
            Ray Wealundefined Offline
            Ray Weal
            What's the timescale for a solution to this problem or is there not likely to be one?
            • Ray Wealundefined Ray Weal
              @Ray-Weal can you confirm the issue still exists?
              I received word from HERE on Friday saying changes have been made regarding the roundabout exit angle issue. I do see significant improvements for the test cases I did in The Netherlands.
              If you do still experience the issue, please share where it happened with a screenshot attached if possible (or recreate the route for me) 🙂
              Vince Hydeundefined Herko ter Horstundefined Ray Wealundefined 3 Replies Last reply
                Vince Hydeundefined Offline
                Vince Hyde
                @Corjan-Meijerink I can confirm that 4.0.7 - 239 has the UK roundabouts correct
                Lynchy67undefined 1 Reply Last reply
                • Vince Hydeundefined Vince Hyde
                  Lynchy67undefined Offline
                  Lynchy67
                  @Vince-Hyde
                  Yep me too all good now in the UK.
                    @Vince-Hyde @Lynchy67 Amazing to hear that! 🙂
                      Herko ter Horstundefined Offline
                      @Corjan-Meijerink does this fix need a map or even an app update to work offline? Or does it just work?
                      • Herko ter Horstundefined Herko ter Horst
                        @Herko-ter-Horst not entirely sure to be totally honest!
                        I would recommend updating your offline maps to be on the safe side 🙂
                        However, I do think that being connected to internet at some point will be enough.
                          Ray Weal
                          Thank you Corjan!
                          • Mark Hamilton 0undefined Offline
                            Mark Hamilton 0
                            This doesn’t appear fixed for me
                            iPhone 13
                            4.0.7 239 MRA version
                            Route line in map takes correct route around roundabout but current and next instructions show correct exit number but wrong direction around roundabout. Also lane instructions are not always correct at roundabout approach.
                            Incorrect instruction but lane guidance is correct
                            Incorrect instructions and lane guidance incorrect
                            Incorrect current and next instructions
                            • Dave J 0undefined Offline
                              Still having the problem too. Only tested on Android though.
                              Ducati Multistrada V4 Rally
                              iPhone 15 Pro
                              CHIGEE AIO-6 LTE
                              CHIGEE AIO-5 Play
                              Richard 18undefined 1 Reply Last reply
                              • Herko ter Horstundefined Herko ter Horst referenced this topic on
                              • Dave J 0undefined Dave J 0
                                Richard 18undefined Offline
                                Richard 18
                                Hi Corjan,
                                You asked that others report the same problem, if they see it.
                                I had exactly the same problem here in the UK yesterday.
                                This was using:
                                A. A brand new iPhone.
                                B. Freshly downloaded and installed HERE maps.
                                C. A freshly downloaded and installed MyRoute app.
                                See here: https://forum.myrouteapp.com/topic/5907/a-strange-little-glitch-it-suddenly-thinks-i-am-driving-on-the-continent
                                • Nigel Freemanundefined Nigel Freeman referenced this topic on
                                  Can confirm the issue is fixed in the next update! 🙂
                                  OGRIIIundefined 1 Reply Last reply
                                  • A Former User? Offline
                                    A Former User
                                    Roundabouts still not showing on Android Auto
                                      tonyS
                                      Things don't look too good in Morocco either
                                      ![alt text](image urlScreenshot_20240117_143917.jpg )
                                      Herko ter Horstundefined 1 Reply Last reply
                                      • Jörgenundefined Offline
                                        @tony-v first exit is OK for me. The Icon is may be not clear enough.
                                        iPhone 12 pro (iOS 17.0.2)
                                        Oukitel RT3 (Andr. 12)
                                        Samsung Galaxy XCover 4 (Andr. 9 Pie)
                                        For more information, click here
                                          @tony-v I doubt that's the same issue. Could just be a single roundabout for which the symbol doesn't match the actual road layout. At least it's not trying to send you the wrong way round or to the wrong exit.
                                          OGRIIIundefined
                                          OGRIII
                                          Jörgenundefined
                                          Dave J 0undefined
                                          Richard 18undefined
                                          Richard 18
                                          Mark Hamilton 0
                                          Vince Hydeundefined
                                          Vince Hyde
                                          Lynchy67undefined
                                          Lynchy67
                                          Simon Ferrariundefined
                                          Simon Ferrari
                                          tonySundefined
                                          tonyS
                                          Ray Wealundefined
                                          Ray Weal
                                          David Parsons
                                          A Former User?
                                          A Former User
                                          • Arrow behind the actual position on Android Auto
                                            Mzokkundefined
                                          • Herberekenen loopt vast
                                            Bouke Entundefined
                                          • Battery drain
                                            1.4k
                                          • Should Pixel 8, Android Auto and Android 16 Work?
                                            ginoginoundefined
                                            ginogino
                                          • Android Auto bugs and improvements
                                          • Vraag over gebruik tablet
                                          • Split route by km
                                            Reinhard-32undefined
                                            Reinhard-32
                                          • Is it possible to view multiple routes from my library at the same time?
                                            RetiredWingManundefined
